shackle problems | Ford Explorer Forums
shackle problems
limited5.0v8
2000 limited 5.0
what size and type of bolt should i use if im putting on autozone shackles and and feel free for more input p.s. im not planning on getting warrior shackles
I think the stock ones are 14mm (and should work with the AutoZone shackles) but if that's not available, I think 9/16"s will work. Grade 8 of course - or whatever the equivalent is for metric if you're sticking to metric.
I have the auto zone shackles. If you only plan on doing some light trails and going through mud, they'll be fine. The bolt on the stock shackles is to big for the hole in the new ones. just drill the hole big enough or use the bolts that came with the new one. I've had mine on for a little over a year now, no problems.
