fr8mscr8pr
- November 22, 2008
- Shreveport, Louisiana
- 00' Explorer XLS
Last night I installed my keyless entry and remote start on my 2000 Ford Explorer..Everything works fine with that. However when I was locating my Tachometer wire I took my instrument cluster out. When I did there is a cable piece that goes to the shifter piece on the column. I started to remove it and noticed that there was a wire inside that I could not tell where it was hooked so I pushed the plastic end back where it went. Now herein lies the problem (before this the truck ran perfectly) Now when I start my truck it vibrates horribly and its coming from the Tranny the engine idle is fine and there are no weird noises just vibrations. It is especially bad between 45-55 MPH. In park and nuetral it is not so bad but when put in gear it gets considerably worse...Any help would be greatly appretiated as this is my Daily Driver.
