SCEXPLORER
- December 30, 2000
- Los Angeles, CA
- 1997 Explorer Sport
I really can't decide to keep on the boots or take it off. What do u all think and why?
Originally posted by BoatsRcool
i dont use them. they are a ***** to put on, and either way water WILL get in eventually and this way it wont stay inside the boot.
Originally posted by SCEXPLORER
A local 4x4 shop said that if you don't have the boot dirt can get inside the shock as the piston moves up and down.
Originally posted by wabbit
I have boots on my shocks. I think it best to preserve the piston rod. It's not so much the dirt, that is mostly cleared by the first wiper seal, but the potential for rocks, gravel, etc. to fly up and scar the piston rod.
The trick is to make sure you seal the boots well and locate a small drain hole at the bottom of the boot.
hate to tell you but if you got rocks coming to hit the piston hard enough to break it, its gonna break wheather or not the boot is on
Originally posted by AdamCKach
I don't use them on my RS5000s due to a friend with a 95 Wrangler removing his to find that the trapped water and dirt caused premature wear on the rod (yes, his had drainage holes, but they can become clogged just as any drain can). They *look* good, but at least on my Explorer, would be impossible to see due to its stock stance.
Originally posted by mattadams
mine are coming off this weekend.
