janolsson
- July 6, 2009
- Leicester, UK
- No Ex at the mo
For those of you that have read (and replied with help) to my previous threads about my recent woes i appologise as this post might be a bit of a ramble for full disclosure of events.
Initially i had my front chains done by a mechanic but he couldn't get the upper sump to seal. So i took out the engine and while sorting out the sump i did the rear chain stuff. Whilst reinstalling the engine i didn't have the Torque converter seated properly and tried to pull the 2 together before i decided it wasn't right. After doing it properly i put everything back together but when running i had a rythmical rattle around the bell housing.
This week i took the transmission out and spinning the TC around it feels smooth and fluid is being pumped. So i took a look at the flexplate and turning the engine 180 degrees there is a difference in a measurement at the same point to the block. So today i planned to take off the plate and the collar to check for trueness.
Then is where i came across another prob. i needed to turn the crank to fit the locking tool to hold it to undo the flexplate but it jammed. This made me remember the the way the engine came to a bit of a rattling halt the last time i turned it off before removing the tranny. So i removed the left rocker cover to find the new rear chain i fitted had snapped.
Now i have moved this chain i can turn the crank by hand so i may have been lucky and not done any valve or piston damage.
Is this wishful thinking or does anyone have experience of rebuilding ex engines with snapped chain???
I'm getting to the point where i'm thinkin of breaking the car to recover some of my costs so far. Tho i might take the engine out this week and redo the rear chain and have a look at the flexplate and collar. I may as well as the engine is ready to come out now. I don't want to pull the head tho.
What would you do???
Would be a shame to break as otherwise its in good shape but i can't afford another engine.
Ta
Ta
