Side Mirror replacement for 2009 | Ford Explorer Forums
NightRock
Dubai
98 XLT,2009 Explorer EB
Anyone here happened to replace the oem side mirror with after market one. We all know there is a blind spot on our 2009 explorer i wanted to changed it with different type without sacrificing the looks
Personally I would just spend the $3.00 on the quarter round blind spot mirrors that they sell at most automotive parts stores and stick it on in the lower outside corner and leave it at that. It is a lot easier and cheaper that way; this is what I have done with all of my vehicles and I no longer have any blind spots.
I have done that already but still im not satisfied with it old explorer is having better side mirror. Can we adopt the latest side mirror with sensor in older model
When you are talking about the mirrors for a 2009 model, a blind spot quarter round in the right spot will fill everything in since the mirrors for the 06-10 model years are quite large. Instead of the outside, bottom corner for the blind spot mirror you could try the upper inside corner and see if that is what you want.
If talking about going from the 06-10 mirror to a 11-13 model year mirror I don't see it happening because you are talking about wiring/mounting and controller differences.
You could also try something like this. I have never tried them, but they look like they might finish off what you are looking for in terms of full coverage with a quarter round in the lower corner and these on the inside edge.
http://www.etrailer.com/Custom-Towi...+Trac/2006/KSCW2100.html?vehicleid=2006308468
And this is a link to the product that I have used on all my vehicles and have been referring to:
http://www.oreillyauto.com/site/c/d...spot+mirror_-1_2654&keyword=blind+spot+mirror
First link seems like better but it will take time to be familiarized to use it like the small round mirror
Second link looks better but does it fit in the side mirror casing
The second link is what I have put on all my vehicles. On the drivers side mirror of the Mountaineer (Explorer) it is placed on the mirror in the top inside corner. On my wifes car (Ford Fusion) it works best on the bottom outside mirror corner of the drivers side. The second item is a quarter round and takes up about the same space as a 2.5" round but gives better visibility because it is essentially 1/4 of a 5" round mirror (I personally think that a full round blind spot mirror shows too much and makes it hard to visually process).
Thanks buddy i will this and see if it will suite my visions
