Driver's side mirror replacement | Ford Explorer Forums
Swamp Fox
Pee Dee Region - SC
'04 XLT 4WD K-flex 4.0 V6
I found a thread that detailed the passenger's side mirror replacement. Is the driver's side basically the same? Any possible issues to look out for? Thanks for any help. BTW, I have an '04 Ex XLT.
I believe they are the same. Take the panel off and you should see the screws;) Don't forget there is a screw under the switches. So take the switch cover off for that screw and after you get the other out, pick the panel UP to take it off. Otherwise you will break some tabs.
Thanks for the feedback. It's much appreciated.
