flyfast
- June 13, 2013
- 07 Sport Trac Limited 4.6
Hello all, brand new to this forum, but not new to forums.
I've got an 07 ST Limited 2WD Limited and I'm having a few issues with it as of lately. There is a lot of good info on this site and cheers to those that help us from keeping from hard lessons learned from y'alls mistakes. (no pun intended!)
My biggest issue is the passenger side mirror I recently broke the glass on backing out of my garage. Didn't seem to bust up any of the plastic, just the glass. I've found replacement online for $110 for a powered mirror (no heat) assy. But the thing is, My caps are painted to match the body and I'd like to keep it that way without visiting a paint shop.
Is there a way to just replace the glass or does the whole assy have to be changed? If so, can I simply transfer the painted mirror cap on to the new assy?
If the assy does need replacement, what's the easiest way to remove the door panel to go about it?
Haven't figured out the search feature on here just yet so any help will be very much appreciated.
Thanks!
Thanks!
