side pipe exhaust | Ford Explorer Forums
side pipe exhaust
95offroadx
Palmyra, Pa
91 explorer xlt
ok im seriously thinking about gettin new exhaust for my truck, and im thinking bout side pipes lightning style, dual tips, and on the passenger side, the only problem i see is that the rear leaf spring hanger is in the way, and i dont want alot of exposed exhaust pipe, but can you post pictures of side pipe exhaust setups?
If you run the tips at a 45 you can go in front of the spring hanger. There are mufflers that have the inlet and outlet at the same end. So you just need a 135 bend at the outlet and you will have the right angle for side pipes. Those muffles are very expensive. I think Roush has some. Maybe if you find a muffler with a small enough body you could run a U bend and still stay within the frame and that would bring it far enough forward to exit at the 45. Think S shaped exaust.
Sorry I don't have any pics.
Side Exhaust is no problem for a good shop, you just need a short muffler.
Mines a 14 inch magnaflow.
You really can't compare that though. That's a 2003 sport trac, Very different from a 91 X.
But yeah a good muffler shop should be able to fab something up to work. I don't see it being very hard at all.
