signal light problems tried everything i know to do HELP!! | Ford Explorer Forums
kj4kym
Kingsport Tn
96 XLT Control Trac 4WD
well first off its a 96 ex 4.0 v6 4x4. When i bought it used not left nor right signals work and when i tried the hazards the right side would come one a hang on and wouldnt blink. so i drove it like this for a while and then my window was sprayer quit working too so i figured that the mf switch was going bad so i bought and new one and replaced it today. well i really hoped that this would fix my problems but all it did was make the right turn signal work and it works fine. but the hazards still hang on the right and the left still doesnt work at all. so i tried replaceing the flasher under the dash but still did the same thing. so i searched under the hood and i found a bunch of relays or something in a box beside the battery and i pulled all of them out but the right turn signal worked even with the all of the relays of flashers out that are beside the battery and all it does is stop the clicking noise when the signal is on. but other then that im pretty much at a loss for what else so check. also ive already checked all the bulbs and fuses and there all fine so i just idk
bump! I REALLY NEED HELP!:us::salute:
Have you tried checking or cleaning the hazard switch? Are all the the bulbs ok? tested on the right side? or been replaced?
thanks for the info ill try this stuff out, ''when im off''' :(:us::salute:
