simple lift ?? | Ford Explorer Forums
simple lift ??
badgett
Mount Airy , North Carolina
1998 XLT 4.0 SOHC 4x4
I have a stock 98 4d. I would like to lift it an inch or two but I don't have the money to put a lot into it. I know I can lift the back with some shackle. Is there a cheap way to raise the front a little?
Yes! Lifting the front is free. You can get about 2" by cranking the Torsion bars up. Be sure to get an alignment after you play with the torsion bar adjuster bolts!
thank you for that info. I had no idea it would be so easy. I will craw up under the front and check it out.
