Skyjacker, spacers, shackles?? | Ford Explorer Forums
jiimi
St. Mary's County, MD
'92 4door 4wd XLT
Ive been looking at the skyjacker lift kit for a few more inches of lift on my X, I was wondering could i use the skyjacker 2" lift, and extended shacles and coil spacers for another 1-1.5" of lift? Or would this be too much front end lifting and require alot more front end work?
I had the exact question only I wanted to do it on my current 5.5 superlift. I am told that it is still possible and will work. Hope this helps. I am not sure what the skyjacker lift consists of.
I am running the skyjacker 2" lift, and extended shackles with no problems. But If you do a search you’ll find that if you put coil spacers on with the lift it will be to hard to align.
Anything above 2" and you will have to install drop down brackets for the TTB. So coil spacers and the 2" coils wont work without other modifications. I myself am considering purchasing the 2" skyjacker soon. Cheapest I have found is www.rockymountainsusp.com so I will get 4wpw to price match them.
