Slipping 3-4 issue 5R55E | Ford Explorer Forums
Dre
Largo, FL
2015 FPIU
I just went through the entire tranny which was slipping big time while going into O/D. I have replaced broken O/D band and replaced VB gasket. After installing this tranny back in the truck I'am getting a slippage while shifting from 3-4. Not much of slippage but still... what could that be?
Talking about a 98 "X" with 4.0 and 5R55E.
Did you replace the servos?
nope... I did check the seals though and everything was OK... you think it might be servos? perhaps band out of adjustment? although I did adjust the bands like ten times... trying to fool myself that it's gonna help.
I think that it might be a problem with the servos. They dry out from the heat of the exhaust, and leak. This will cause a problem when the band is applied. It might engage, then slowly disengage causing a shift flare. Make sure that the heat shield is in good condition.
heat shield is missing... looks like I need to order new o-rings for the servos and start from there.
Looks like I'm gonna have to open it again. Oh well, ordering parts.
thanks,
BTW - transmission would slip in all gears if servo was bad - right? why just 3-4 gear?
perhaps I did not lubricate servos properly?
