Thallarsen
- February 21, 2000
- Potomac, Maryland
- '99 5.0 Limited AWD
When I drive for short distances, everything seems fine; but after warming up and driving at highway speeds for awhile, the engine seems to go into a mode where it has sluggish acceleration and less power. Almost like I'm towing a trailer. Not much pinging or missing unless I step on it.
Usually it’s fine, and cruises up a steep hill at 80 without a heavy foot - but sometimes, it takes more gas to do it at 65 w/the same tank of gas, same conditions.
It seems like an ignition or mixture issue. I’ve recently replaced the plugs, wires, trans. modulator valve, thermostat and intake gaskets (retorqued after 2k), and run a few bottles of injector cleaner thru the system. I don’t think that it’s an intake problem, since I’ve checked the vacuum lines and retorqued the lower intake bolts. Also, the symptoms are sporadic as if it were a sensor that was acting up or something.
Recently, I replaced a faulty thermostat that kept the engine way too cold, I then disconnected the battery overnight to ‘reset’ the computer. I think it made a big difference, but I still have this little quirk.
Is there a sensor that effects mixture and/or ignition that may be to blame (EEC, IV, EGI or DIS)?
Also, regarding ignition timing:
On the sticker on the radiator housing, it says “...timing is not adjustable...” but it then says "...to check timing, disconnect small in-line spout connector...”. What/where is that?
I assume that if it advises on how to check the timing, there must be a way to ‘correct’ the timing through the various components (EEC, IV, EGI or DIS) if it’s not right. Otherwise why check it? Which component(s) make the timing right?
Any help/suggestions would be helpful.
