1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
So for a while now my 1996 Explorer V8 has been having a rough idle, nothing serious, I can sort of feel it in the cab, but you can visibly see the engine shaking around. It ran fine so I never worried about it. On Sunday I went to start my truck, and it blew off a Vacuum cap of the back underside of the intake, so basically it misfired? I didn't even know EFI engines could do that. So I bring it to school today to test a few things, first off the fuel pressure regulator is not leaking, and it is working just like it should. YAY! second, I hooked up a 5gas analyzer to the tail pipe to find that my NOx emissions are through the roof!!! at 2,500 rpms the NOx was at almost 400!!!!! So naturally we looked at the EGR system right away. turns out that the hose going from the EVR to the EGR was split, so I replaced the hose, and tested it again. Same test at about 2,500 rpms it went no higher the 260, but that is still very high.
We then took off the EVR solenoid, and did some tests on it. the vent is working correctly, and it works both mechanically, and electrically, so we looked at the EGR, it works just fine, we hooked up a vacuum pump up to it, and did the same test as before, the NOx was now below 100, which seems to be pretty good. So my question is, do you guys think that the valve is too clogged up to open fully or at all with the little amount of vacuum supplied from the EVR solenoid? I had to apply quite a lot of vacuum to allow the valve to open enough to bring the NOx down. Also can I simply clean the EGR valve off to fix this issue? I have this amazing foaming top engine cleaner from AC Delco that basically eats any carbon build up right up?
Thanks guys. I can pick up a can of top engine cleaner from work tomorrow before I go into school, so some input tonight would be appreciated.
