koda2000
- September 2, 2011
- x
Update:
Not much progress to-date. My allergies and family issues prevented work on the ST most of last month. I did mange to strip down the top off the engine, labeled everything, got the passenger side header studs and header off and did some other minor stuff.
Right now I'm struggling with the stupid EGR tube on the driver's exhaust manifold. Bought a 27mm wrench, but the nipple that is screwed into the cast iron header started spinning (rather than the EGR tube's nut). I figured out the nipple can be held with a 1" wrench (which I had) and I was able to brace the 1" wrench against the frame while trying to loosen the EGR tube nut, but it won't budge, even soaking it in penetrant for several days and hitting the 27mm wrench with a BFH and has not helped. I'm picking up a new bottle of MAP gas today, but I'll probably end up using the whole bottle trying to get the nut hot enough, as a lot of the heat will get sucked up by the cast iron header. I tried removing the header mounting studs and taking the oil dip stick tube loose (the dip stick tube moves around easily, but I couldn't get it out, maybe if I remove the engine mount plate first?). While I could move the header around quite a bit I don't think it's going to come out with the EGR tube attached, as it's catching on something. If heat doesn't get the EGR tube nut loose I may decide to cut the tube (don't want to do this but... we'll see what happens).
