- April 3, 2009
- Kailua-Oahu, Hawaii
- '05 Sport Trac XLS (RWD)
Ditto above. 1997 "Limited Edition" engine configuration and layout should be no different from other trim levels. I'm beginning to believe the cover was previously modified. Do you have an aftermarket open air intake or a throttle body spacer? If you have a 4.0L OHV push rod instead of the SOHC, this confusion could have easily been prevented. If it's the original engine what is the VIN? As we've requested, please post pics of the damaged engine cover and engine from different angles. I'm losing sleep over this!None of those are mine. 1997 Limited Edition XLT SOHC. Those are so big I feel like they might hit the belt.
8th VIN Digit
E= 4.0L 6 cylinder SOHC
X= 4.0L 6 cylinder OHV
http://www.explorerforum.com/ntrprize/VIN.htm
