BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
@slisman - I have almost the exact same scenario as you had. You didn't say how you determined (specifically) that an injector was leaky. Nor did you say how you determined WHICH injector was leaky.Guys, problem finally solved!
Thanks for all your help.
It turned out that one injector was extremely leaky.
And now - Explorer idles right away!![]()
I've ruled out everything posited in this post (and more). I'm at the point of needing to determine IF one or more of my injectors is leaking... and WHICH injector/s it is. Can you share the diagnostic procedure/s you used to answer these two questions?
