PedroDaGr8
- July 31, 2006
- Lexington, KY
- '98 Ford X XLT
I am going to post some schematics that I have made for random people. I figured I would contribute them here; because as I stated in another thread I no longer have my Explorer (RIP) but everyone on this forum was ALWAYS so helpful (including for my recent question) and I wanted to give back some to say thanks. These schematics are for positive switched systems, but I can adapt them to ground-switched systems if anyone needs me to do so. Also, they are shown for H4 bulbs, but quickly and easily can be adapted to work with ANY bulb as I have labeled what each pins function is.
This first one is one I designed for a user who had bixenon projectors AND a seperate halogen headlight (bixenon projector where the low beams used to be and the halogen high beam was left stock). This resulted in a problem, because everytime he flashed his high beams, it would flash the xenons as well (since they operated as his high beams TOO). This schematic SOLVES that. If the low beams are not on, it only flashes the halogen bulb, if the low beams ARE on it flashes/turns on both. It could be used in a variety of ways. i.e flashing auxillary lights or fog lights instead of the headlights during the day etc.
This NEXT schematic is an off-shoot of the above one. It is designed with a similar purpose, but instead of flashing BOTH at night, it ONLY turns on/flashes the bixenon high beam when the xenons are on. The halogen high beam only works when the xenons are off.
The next schematic I posted in another thread on here, it is a simple wiring upgrade harness schematic. It uses 9007 plugs in and out, but allows the user to run a higher gauge of wire, reducing voltage drop.
If anyone has any schematic requests, I can whip one up pretty quick to do a lot of different things. Just ask me and I'll see what I can come up with.
