Something to check if down on power/mileage | Page 2 | Ford Explorer Forums
I figured I would follow-up here...
I picked up a Motorcraft DGE-446 OEM ignition coil pack, got it delivered today and installed it an hour ago... I will say it runs just as well (if not a little smoother) than with Accel 140035 coil pack.
I have put the Accel back in the box and it is on the shelf as a "known good" spare for now.
I even picked up a replacement coil pack for my 2001 Mustang. I will see about putting that in sometime this week, but that isn't coming out of storage until we are into spring a while. It has Indy 500 tires that suck at temps below 45 degrees, and especially with cold pavement they would be dangerous.
@DP96XLT
Just sayin' - don't forget to reset your pcm/ecu (again) to fully take advantage of the new coil parameters!
Good to hear that you're working your way through all the issues :)
