bruce119
- June 14, 2010
- Holiday, Florida
- '93 Explorer
Well I was having problems with a bad running truck bad idle pore acceleration. Couldn't find the problem changed MAF, FPR, IAC and a few other to try and fix. I have a donor truck so that didn't cost me a fortune.
Any way i read about a LOT of other trucks with similar problems.
I took her to the dealer $$$ I know but I was desperate. I needed a PCM but that wasn't the real problem. The problem was the "Air Hose" that is the molded hose that goes between the MAF and the throttle body. Evidently there was a crack in the seams and went unnoticed undetected by me and other small shops.
So maybe this will mite help someone else who is having problem and can't find the problem. Be sure to check your intake air hose. I would think a good way to test would be to remove seal the 2 large ends and put a vacuum or pressurize using the oil line hook-up.
hope this helps some one.
Thanks to all that helped me I am sure there will be more questions in the future
Thanks
Bruce
Thanks
Bruce
