Something wrong with right side steering? | Ford Explorer Forums
Nate1
All 4 wheels locked
Gainesville/Tampa, FL
'96 FZJ-80
I was messing under the truck seeing what I needed to extend my breathers and I noticed where I guess my tie rod (if not, whatever R&P steering has) connects to my spindle is not sitting flat!
I dont know if this is a problem... but if you took a level and set it on top of the head where it joins, you would see it is at a much worse angle than the picture shows.... is this a problem to be concerned about, or the cause of all my steering popping?
Yes that's your tie rod end, and no it does not have to sit flat.
Your tierods are fine.
