Sometimes my 96 just will not start... | Ford Explorer Forums
geebob
McLean
96 Eddie Bauer
When the vehicle is cold the car has no problem starting however, once it warms up, you stop to run an errand and attempt to restart the vehicle, it may or may not start. There is no pattern to this behavior what so ever. You could start it 10 times in a row then all of a sudden you go into the store for 5 mins., try to restart the car and it simply cranks. After waiting anywhere from 10-20 mins. it will start again. What is the deal?
Bad Crankshaft Position Sensor is one possible cause. Search for more info....
Is there any visible corrosion around the battery or cables? Even if there isn't, it could be your cables starting to go. Electrical resistance increases with temperature.
96 not starting
Thank you for the tip. I will research this just a titch more
Thanks
Very good suggestion. I will do just that and see...
