Sound quality ? | Ford Explorer Forums
Sound quality ?
jakejeff
ontario
1994 xl
I have:
Head unit - Blaupunkt 52x4w
Amp - alpine 50x2 rms
front door - 6.5 blaupunkt handles 50x2rms (not componants)
rear speakers - factory speakers
The blau speakers and amp are not hooked up yet but I plan to run the front door speakers with the amp and the rear speakers with the head unit....... Is this O.k?
so how do you thimk this will sound I am not looking for alot of base just louder and clearer?
please any suggestions
thanks!
dudemy friend has Blaupunkt speakers in his car and thay sound bad and he is running below the rms of the speaker just becare ful i would sell or return those and get some others
just my opion and just tryin to help
usually best to go component when you amp rather than the coaxials. takes enough labor to run the amp, might as well put some speaks in there to really enjoy it.
I dont know the specs of the amp but you may be (most likely be) able to wire in parallel and run all 4 speakers @ 2 ohms. You'll lose the fading but have the juice. I'd opt for this vs. the amp & deck power together.
A good balanced speaker system would be the Diamond Audio S600S. Best components for the dollar. These have crossovers with outputs for rear fill you can wire in a nicely balanced system with these (use the blue dot coaxs in the rear).
