Sounds like a miss.. | Ford Explorer Forums
Firestorm
Cleveland, Tennessee
2001 EX Sport 4.0 SOHC
Gentlemen.
Whilst idling my vehicle seems like it is missing. This jars the Ex a little bit, seems like it does this 3 times in a row, waits about 20 seconds then repeats.
I had noticed a slightly audible hiss coming from the driver's side engine compartment. You get a really good ear full if you turn your wheels to the right and stick your head in. Sounds like it is coming from the exhaust manifold.
A friend of mine tells me that this is probably a doughnut gasket? What do you guys think? Also, would this cause that "miss"?
Engine isn't throwing codes. Any advice is welcome.
Thank you.
-Nathan.
Plastic underneath the wheel well on the left side is hard to remove. I nearly destroyed it last weekend while I attempted to remove a dent that I put into the left front quarter panel.
Basically then, it seems like I have this isolated? I think it has to be somewhere around the exhaust manifold? That's what it sounds like from the outside.
Thanks bud.
Alright. I really appreciate you guys. I'll attempt to tighten them.
