spark plug question | Ford Explorer Forums
spark plug question
dannyces
syracuse, new york
95 xlt
ok well its actually a question about wires... i am doing the front brakes tonite and i wanna put in the plugs i've have sitting in the truck for 3 weeks now my question is, is it ok to use the wires that are on it already or does the wires have to be changed when i do the plugs??? i plan on doing them soon i just dont wanna waste any time tonite running to the parts store
Danny
Hello,
How many miles on the existing plugs/wires? It's usually a good idea to replace the plugs and wires together.
Good luck,
ERUSH
hey guys thanks for the replies
well i didnt get to it anyway the brakes ah the brakes:mad:
both bleeder screws are shot and two of the four slide pins are completely rusted stuck. the inside pax side pad is about 1/8" basically just the plate is left and the outside pad looks brand new. the rotors are also useless. so thats gonna take some more time then i thought.
thanks again
Danny
If you've never changed the plugs/wires and don't know when the last time they were changed was, then I would go ahead and do both. However, if you have a repair manual you can check the resistance on each plug wire to see if they are out of spec and need to be replaced.
that seems like way to much work:cool:
the truck is somewhat new to me so i have no idea when they were changed so i think i will be doing it soon with the new wires
Danny
If you are just replacing pads, you don't need to bleed the system. If you do want to bleed, you can try bleeding where the flex line goes into the caliper.
hey im doing pads and rotors and flex hose. so right now my main problem is i cant get the guide pin out of the bracket. its completely rust together. any ideas????? also any ideas on how to plug the lines so i can take the calipers off the work on them inside????
Danny
