spark plug wires | Ford Explorer Forums
spark plug wires
TheIceMan
Bushkill, PA
"04 Explorer xlt sport
This may sound stupid but I am trying like heck to get the wires off so that I can change the plugs. These suckers won't budge... Its like they were crazy glued on. Any suggestions??:mad:
Try to twist the boot first before you yank on it. That'll break it loose from the plug and then you can pull it off gently. If you reef on them too hard, sometimes the wire will break internally and can cause misfires. If you planned on replacing them, then that's a moot point, just rip 'em off.
If/when you install new wires, get some dielectric grease and apply a small little dab in each boot. That will prevent them from siezing on like you have going on now. Don't use too much though...Too much grease can actually boil and force the wire off the plug. I learned this the hard way on the race car. Now I just put a tiny little dab on each one...Just enough to coat the inside.
Any brand of plug wires any better than the others? I may swap mine out soon.
Motocraft, or if your serious Magnecore.
They can conduct maximum amount of amperage to the spark plugs due to their internal construction. This is especially beneficial if you're running a hotter coil which is lots of times necessary with addition of a power adder (i.e. turbo, supercharger, nitrous). They're constructed with actual metal wire wrapped at 200 turns per inch around a magnetic core, which eliminates radio frequency interference (RFI). Other aftermarket "performance" wires lots of times just use a silicone or Kevlar core embedded with metal particles which breaks down as voltage passes thru it. This way they can use less metal wire and still be impressive in little bench tests that compare one wire against another in low voltage resistance tests. You'll see them advertised as "ferrite" or "spiro-core" or "superconductor" or a multitude of other catchy meaningless names.
For average daily use, they're probably overkill, but they will probably outlast the vehicle, rather than needing replacement every few years like most other aftermarket plug wires. They're incredibly expensive though...I priced their KV-85 race wire set for my Explorer, and they were around $140! Their Powersports (i.e. stock replacement) series weren't much cheaper...I think they were like $109 or so.
For a decent stock replacement, I like Carquest's premium line which is made by Prestolite, the largest supplier of OEM plug wires. They look, feel, and fit just like original equipment. NAPA's Belden Max line is also very good.
Definitely avoid the better majority of the aftermarket wires though...Especially those found in "discount" auto parts stores like AutoZone, Advance, etc. Most are made very poorly and are designed to fail within a couple years. Advance Auto Parts carries Autolite wire sets, which not to be confused with the spark plugs of the same name, are terrible at best. Autolite plugs are excellent, but whoever supplies the wires for their brand of wire sets definitely isn't up to the same standards. AutoZone's Duralast wires are garbage too. I've had some of them be bad right out of the box.
Motorcraft wires are competitvely priced to most the good aftermarket sets, and are also of excellent quality.
