Originally posted by DOGMAN
Al and Adam,
Performance plug wires, such as the ones Al mentioned (there are a number of others also, such as MSD), work well. But honestly, the stock Ford ones are pretty darn good. The performance wires arn't cheap, they start at about $30 or so, and go up from there. If the motor and ignition is all stock, I really don't see the need for upgraded wires. I don't think you're going to see a gain in performance just by replacing the plug wires. Now if you upgrade the ignition (MSD, Jacobs, etc.), then I'd go ahead with the performance wires. But if everything else is stock, I'd stay with the Ford wires and spend the money somewhere else, like a K&N or upgraded muffler. Now, if you want the performance wires just because they look cool, hey, there's nothing wrong with that. I think they look cool too. But strictly for performance enhancement, you're really not going to get anything significant from the wires alone.
To add about the Bosch +4 plugs, after my problem with them, I started thinking.
Bosch says they use four electrodes per plug for maximum spark efficiency. So how come all the racecars don't run four electrode plugs? Seems to me that with a four electrode plug, there's three more chances over a regular single electrode plug that the gap could be off. Think about it. Gap is a critical factor in spark plug performance. My observation is that the electrodes on the +4's are not as stout as a regular single electrode plug, hence it would seem to be easier for them to become misaligned. On the +4's I ran, that definitely was the case.
And those who are very serious about performance don't use platinum plugs either. The platinums are made to last a long time, not to be the utmost in performance.
The easiest noticeable performace gains are to add a K&N or KKM, or a performance muffler (Flowmaster, Dynomax, Magnaflow, etc), or both (preferred). After that, the best money spent on the 4.0 would probably be the addition of a performance camshaft, which is in the $200 range. That will net you some nice, noticeable gains.
