speaker installation | Ford Explorer Forums
willranger
Fairfield, TX
1984 Ranger
I have six factory speakers out of 1995 Taurus. These are the rear speakers. I want to install all six of them in my 2007, E350, 15 passenger van. For now all I have is the factory radio but plan to upgrade to an aftermarket system. Will this work? most cars/trucks have two small speakers and two large speakers. How will six large speakers work?? I'm not interested in blowing out windows etc. Thanks
Don't bother using the factory speakers. And they won't work on the factory headunit, cause you'd be splitting the wattage of 1 channel across 2 speakers.
So if the stock radio puts out 16 watts RMS, you'd be sending about 8 watts to each speaker.
6 Speakers doesn't sound different than 4 in a stereo configuration. It just gives you more coverage in the car.
Coverage is just what I was looking for. So my concern is the hook-up. I'm thinking that all is needed is to keep the same polarity for all speakers.
Keeping the polarity on the speakers will work, but you'll lose volume, greatly lose volume. The best bet would be to run a multichannel amp and run the speakers off it.
If you split 4 channels into 6, that means you're going to run 2 speakers off 1 channel. Like I said before, you'll split the power/volume.
That means, 2 speakers in the car will be louder than the other 4.
After all that, it's not worth it, unless you want to add 4 more speakers. Then get a 4 channel amp, run 2 speakers off each channel. So 4x2=8.
If the amp is a 1000 watt amp, that gives 250 per channel, you'd be giving 125 watts per speaker in an 8 speaker set up.
The stock headunit puts out 16 watts rms. That means you're giving 8 watts per speaker.
Big difference!
Also, running too many speakers on the factory amp can blow the amp from stress.
Wow. Much more to this than expected. The van only came with an Am/Fm unit so I will be replacing it. It seems like I will need an amp also. Normally do amps work with speakers in pairs? 2, 4, 6, 8 etc.? I'm not looking for a high power system just something to make the speakers work. I haven't searched but a 100 amp booster would be top of the line for me. I don't want to buy any speakers if I don't have to. Hopefully my collection will work.
Best choice is a 4 channel amp.
And try to pair the speakers based on their type.
If you have 2 of the same speakers, run them off the same channels if possible.
You can split a 4 channel to power 8 speakers.
Or, you could get a 5 channel amp, that way you an run the speakers and add a subwoofer if you want to later on.
thanks a million for all of the info.
No problem.
Hopefully it works out for you. Feel free to bug me if you have any more questions or need more info.
Just make sure that your ohm load is correct whatever route you go. You don't want to overload the amp's capability, that'll blow it real quick. Say you take 2 4ohm speakers and kept the polarity the same to go to 1 channel, you would then be a 2 ohm load, so if you do plan on using a 4 channel amp or even off a headunit keep that in mind. If you go with a 4 channel amp that is stable for 2 ohms, that usually increases power for that channel, so you could have all the speakers at almost the same volume
Oh wow, thanks for adding this. I actually forgot about ohms when explaining this to him.
Thanks for the info. I will research the stats on those speakers to see what ohms they are. They all came out of Taurus cars. I have until December to finish this project. My main thing is not to buy new if possible. I prefer takeing salvage stuff and making a good product.
Door speakers are 4 ohms. Putting 2 door speakers together makes it run in 2 ohms.
Only in ohms can 4+4=2..
You'd have to look into it and research ohm load.
