92302expo
- August 21, 2011
- Lufkin, Tx
- 92 Expo xlt 4x4 5.0
Does anybody know of a 15 tooth speedo gear that will work in a first GEN? all the calculations I’ve done say I need a 15 tooth gear to correct my speedo. Stock setup was 6 tooth gear in t-case, 17 tooth on speedo cable, 3.27 axle gears and 29” tires I have since changed to 4.10 gears with 33’s.
Update: Turns out I have a 7 tooth gear in the t-case, so my calculations say I need an 18 tooth gear.
