Herman
- January 20, 2009
- South Jersey
- 2001 sporttrac
Hi,
I have a 2001 sportrac. The speedometer is showing real high speeds. For example, if you are doing 25 it says around 45.. if you are doing 40 it shows 80 or so. The rpms seem OK except when I think it should go into OD it doesn't seem to drop back to the 2500 but stays up around 3000 rpm. Also, when you first pull away it seems to be a little jerky but smoothes right out. There also seems to be a bit of a whistle when moving. I took it to a AutoZone and they tested it with a meter and it passed... no error codes showed up. I had suspected a bad speed sensor up to that point but now am completely confused... Help.
Herman
Herman
