Spider Gear Replacement | Ford Explorer Forums - Serious Explorations
GJarrett
Moderator Emeritus
Location
Tampa, FL
Chief GPS'um and Still Lost Native Texan
'99 EB 4x4 "Herc" RIP
I have a friend that bought a used Jeep Cherokee that had no diffy fluid in the rear axle. He refilled it and it worked for a couple years, but now the spider gears are stripped. He thinks he has a Dana44.
I'm trying to remember exactly how mine looked and fitted in the diffy, but cannot recall exactly. Am I correct in assuming that he can simply replace spider gears without worrying about resetting the gears/pinion depth/etc? If my memory serves correctly, I think he doesn't even need to remove the ring or pinion, does he?
He's a decent shadetree mechanic and wants to know if this is a DYI job. I'm thinking he can..... right?
Yes, you can change the gears without removing the carrier.
