spindle lift on a 2000x 2wd | Ford Explorer Forums
ivrb
southern cal
2000 xls
On my 2000 x 2wd I have spindle lift, I've extended out the camber all the way out and still cannot get the tires straight, do I need ext a arms? or what else can be done? Any help or ideas please.
I dont know if they are stock or aftermarket I just moved the adjusters all the way were it'll push the spindles all the way out, that eccentric plate almost did not almost fit between the two tabs. I moved them to the highest flat part if I used the edges of the highest part it will not fit between the tabs
also checked the elongated hole and the screw was hitting all the way out.
