Spontaneous Tach | Ford Explorer Forums
Spontaneous Tach
00XLS
Frackville/State College PA
Explorer 00 XLS
In my 00 the tach doesn't work all the time, sometimes it jumps to life and the other times its dead the whole time. Any ideas?
I was going to say check the wires that go to the coil, but I am not even sure we have one. My old ranger had a loose wire and did that.
I was thinking a loose wire somewhere as well, if I give the dash a tap SOMETIMES it will work but only for a minute. I thought maybe I loosened something when I installed my gauge bezel but I checked everything and it was all tight.
Not real sure where to look. If (huge if) we still have a coil, the tach should be hooked to it somewhere. Do you have a maintenance book you can look for the wiring in?
On the old ranger, one wire was just loose and made contact when it wanted to.
I have one huge coil pack, I'll look around there for a wire of some sort. I do have the factory cd so I'll take a browse on there
Thanks Robb. I thought they switched a lot over to electronic junk, but I never looked that close under my hood.
Anymore ideas ?
