Sport trac wheel sizes | Ford Explorer Forums
VendettaFXR
Miami, Florida
2001 Sport Trac
Hi everyone.
I need someone knowledgeable to help me out. So I'm in the market looking for wheels for my 2001 Sport Trac. I have the 15" steelies on in. I know the bolt pattern is 5x4.5
1. what are the precise measurements on the stock 15" wheels?
backspacing, offset?
2. will a 20x9 wheel fit, with a +30mm Offsett, and a backspace of 6.2"
http://marksink.com/tire_wheel_offset/offset.html
If I read this correctly, the tire will be 10mm Closer to the body, and the outer edge of the tire will stick out over the stock by 40mm. is that correct?
If so, do you foresee any issues using the tire in this dimension?
any input is appreciated.
I think the '01s with 15" wheels are relatively few, or at least I don't see many. The ones I do see look to have chrome plated wheels, (more often seen on Rangers), not painted as listed in the link provided. The spec sheet in the link for 2001 has an early date of 07/20/00, so things could have changed later in production.
