Jeff,
You can go the stupidlift method, but the shocks still mount low and your ubolts are facing down also. If I was you, I would do like me
I got a set of warrior spring pads from 4wheel parts- 12 bucks or something. Then I welded them on to the top of the axle. Then I used a bolt in the swaybar holes and mounted my shocks.
The angle? Make the new ones parralell to the old ones. Put two straight edges on the axle
ne on the bottom of the old pad and one on the top of the new loose one. Now measure the distance on both sides between the straight edges and make them equal in front of and behind the axle. Then your angle is correct. Weld them on. I did it myself. I used a Arc welder and was careful to do 1/2 of an inch at a time, because you don't want to get the axle too hot and warp the housing. Weld 1/2 and inch, let it cool. Weld 1/2 an inch, let it cool.... etc. Also be sure to take off the wheels, because They will pull on the axle and make it want to warp.
Doing it when the axle is bolted on? No. Your ubolts will cover the place they want to weld. If you don't want to weld it, might as well take it completely off and take it down to the shop. All you gotta worry about is brakes, shocks and driveshaft- not a huge deal.
My SOA improved ride quality, departure angle and flex. I got about 4.5 inches because I took out the flat overload spring. If you don't want to take off your sway bar, you can get some weld on shock mounts at
www.mountainoffroad.com- If you do a SOA, in the method I did, the spring plates are too high to mount the shocks. Good luck.
