SPRING SPACERS??? | Ford Explorer Forums
SPRING SPACERS???
MARTY196
Albuquerque,New Mexico
1992 XLT
Look up f 150 spacers in the search function. It's a much better solution than the jc whitney product.
No.. that piece doesn't work. you need the f-150 spacers. OR you can have your own spacers made..
call a metal supply company (call many since some charge a lot more than others).. and get two pieces of 4" rolled steel 1" thick. When you get it.. you drill a hold in the center and now you have spacers... You could go 1.5" if you wanted that much..
or... get the f-150 spacers.. but if you didn't really want 1.5" go with the rolled steel.
I have 1 spacer at home that I can measure (the rolled steel kind) to make sure it is 4" if you want..
The rolled steel spacer should cost you $50 or less (it depends on the metal supply store)..
~Mark
