Squeal from the front of my 99 Ranger. | Ford Explorer Forums
Justind00d
vermont, swanton
99 ford ranger xlt 4X4
Yah, i have a 99 ranger xlt 4X4 and it recently started to squeal in the pass, front or the whole front and it also does it when i turn left at about 35-40 MPH. and when im at a constant speed and it will do it and as i go it gets louder! i pisses me off. My dad cant rele hear it but its rele loud to me and i cant figure out what it could be! i need hellp
It is probably the knuckle seal, sometimes called the excluder seal. You will need to remove the wheel bearing and grease the seal behind it and that should fix your problem.
thanks
Ohk thanks, but when i took off my front left tire i noticed tht a rubber seal was ripped where my wheel bearings are and, then i looked at my right front tire and tht rubber seal was fine and the right side doesent make any noise its just the left side, so thts what im thinking it is but im not 100% sure yet..
