squealling like a pig | Ford Explorer Forums
watisgood
LoNg IsLaNd
1997 ford explorer sport
so i hear this quealing sound when i have my car running sounds like the belts...is this a DIY?????:navajo:
Yeah its a DIY..just use a socket( or 3/8's ratchet ??)on the belt tensioner and pull the belt off..you might need to work it around the fan, i cant remember if it needs too..
rehhheally...ill give it a try whats the worst that can happen
no one knows any threads that has a diy...great
Oh its not hard..just a bit of a brain teaser, make sure you got the belt diagram under your hood first..
Make sure its not your belt tensioner either, that could casue noise too, or grease....or a bad ideler wheel bearing
Check your idler pulleys. Mine was squealing and it shattered and ruined the fan and belt.
