Niels
- March 19, 2009
- Benson, MN
- 1999 XLT w/ 4.0 SOHC
The Explorer got all of the timing chains replaced last January. Since then the serpentine belt squeals when the engine is started. I did do a search for this and found a lot of information. The bad thing is that I have done it all! The belt itself looks good, a Goodyear belt. The tensioner has been replaced, once last fall and again this spring. The pulleys all look good as well. The only thing that I can find wrong is that the tensioner is at just about the end of its travel. It's running right at the limit mark on the tensioner.
Since this noise started after the engine was pulled (Grrr) for the timing chains, I thought that maybe there was some fluid on the belt, which was what the mechanic said. But 5K later and the squeal is still there, sometimes worse, sometimes better. I looked at the power steering pump, compressor, etc. thinking that there may be a mounting issue with something. Nothing, it all looks good.
I am thinking that I may need to get a shorter belt. I don't want to because then I will always need to remember the number of it. Anybody ever had this type of problem?
