ST Driver's Door Weather Strip | Ford Explorer Forums
koda2000
x
I'd bet it will fit. I still think the basic doors are the same on the 2nd gen Exs and STs and only the exterior trims are different. Even if the doors are different, they're close enough the weatherstrip should fit.
I put one on my 4dr driver side, can't address fitment on a ST. It seems to work pretty well. As good as stock as I can tell. As long as the door openings are the same shape you should be good to go. You do have to loosen up and/or take off a few trim pieces to get it to fit correctly.
Koda, does this look correct?
F1TZ-7820708-C | eBay
www.ebay.com
IDK. That's my question. Maybe I'll measure one off one of my 4 door Ex's and see if the dimensions look correct. If they are similar maybe I'll pull one off and try it. I was just being lazy and asking if anyone else knew for sure. LMC is quite a bit less expensive even with the shipping. Though I found it curious that the left and right sides appear to be the same part number. Maybe there really isn't a shape to them.
I just measured the front door openings on my '01 EB and '01 ST and they appear to be the same size, so I see no reason a 4 door Explorer weatherstrip shouldn't fit on an ST.
Good to know. Not always accurate, but "See compatible vehicles" lists 167 models and years starting from 1991.
