Stabilty control problem | Ford Explorer Forums
silver08
Ca
2008 Sport trac
2008 Sport Trac
The ignition switch was so easy to get out I tried just squirting some TV tuner cleaner in the hole and worked the switch while I moved the plunger in the bottom up & down. Blew it out, put it back in & it works fine. Too young to be worn out. Lights work right now.
Next problem. Steering angle sensor. The stability control sometimes does whatever it wants. The dealer says the sensor is bad. $400! Where is the sensor? How to change it? Calibrate it?
