Dagwood30
- October 11, 2009
- st. augustine florida
- 2001 explorer sport
I deliver mail out of a 01 exp sport, the problem I'm having is after around three hours of continuous driving the engine will start to hesitate and stumble if you will,the problem gets progresively worse as I keep driving until it will stop running altogether. After around an hour or so it will start right back up and run fine. I have pulled the obd codes and it says rich pe lean condition caused by bad maf sensor or fuel pressure issue. The problem occurs usualy on very hot days,it is an intermitent problem that does not happen every day, I am stumped! Don't want to pay 130 for a maf sensor and still have the same problem,clogged cat converter possibly? Any advice would be apreciated,I'm no mechanic but am capable of minor repairs ,maybe someone has experienced the same problem perhaps.:exporange
