Stalls out when its hot | Ford Explorer Forums
Redneckfixit
Tucson
2000 ford explorer
So i have had this truck for about a year and got it at the end of summer last year and had this problem then winter time run fine its getting vary hot now (where i live im talking 112+)and did well at the beginning of summer 80s 90s but now starts fine runs great tell we have been driving for about 30 minutes with the ac make when makeing a left turn only it will spudder and die out then a little further into the driver it will start doing it when we come to a stop then it just gets to the point where it will only run at a hight ldle and if i come to a stop i have to put it in neutral and rev the motor to keep it high and the other day when i got home from work and it was acting up most of the way home it would not even stay running tell it cool down the cooling system is working properly the fuel pressure is at 55 and no check engine light is on have check for vacuum leaks and any loose connection i keep it vary clen and no sign of anything leaking just don't know where to go from here
Have you check the fule cap. If it's got a bad seal the fi work get the proper vacuum. Or a bad cap can give you caper lock on ex warmed up. Some places have a cap checker.
Its new just replace it two months ago
Is there an automatic correction on this fourm for typing. I type something it looks good I post it and it reads like it came from Mars. I use an iPad Pro
V6? Probably the inlet manifold sealing rings.
May as well change them, you'll have to one day anyway.
Clean the idle control valve too.
Ok will give it a try
