starting headaches | Ford Explorer Forums
starting headaches
robert long
chester VA
98 xlt
Here's the deal. When it is cold out, my 98 xlt starts and revs up and down uncontrollably until it warms up. Once it is warmed up it starts and goes to 1100 rpm and holds beautifully, I was told to replace the intake air valve and I did, but it is still happening.
Helllllllllllllllllllp1 (Thanks in advance)
Do a search this was just discussed a couple of days ago,I think your problem is covered under warrenty:D
Thanks, but I have no idea how to do that. Is it easy?
The search button is at the top of your screen.There are lots of people that no alot more about this problem then I do:D I wish I could help more
Do a search under shakey cold start:D
Do you have the SOHC engine? If so, have you had your Manifold O-Rings replaced? There is an owner notification program that covers the rings and the cam chain tensioners - 00M12. Search 00M12 or O-Ring Replacement and you'll find lots of threads discussing your problem.
