starting problem, just a click, then no power | Ford Explorer Forums
stevedud
Lincroft, NJ
'92 XLT
When trying to start the 93 X, turn the key to the on position, all lights work, turn to start, get a click and all power goes off. No light, radio, nothing.
I replaced the battery and jumped it too but still nothing, click and all power out.
Thoughts?
Maybe starter solenoid?
Sounds like the starter or starter solenoid. Check the connections on the remote solenoid. I had a similar issue and it was just rusted terminals.
probably something rusted out. I just went through the same thing, everything worked except starting. Turns out the battery terminal on the + side was rotton.
Check and clean your battery cables. Also, sometimes the ends look fine, but the cable is corroded under the housing.
Just fixed the same thing. Bad ground wire connections on the battery terminals.
