caaine
- April 11, 2006
- Reykjavik
- 1995 XLT
Hi,
I am unable to get my car to start properly using the ignition. But if I switch on the ignition and use a screwdriver to short the polars on the start-thingie (don´t know what it´s called in English, sorry - partno. ONE SW-1951-C / EZTZ-11450-B RELAY). Then the car starts up normally. I figured the "start-thingie" was broken and replaced it (hence I have the partno). But that didn´t work.
When I try to start, all electrical components come on without a problem and I hear a buzz-kinda-sound for a bit which then stops.
I also checked all fuses (in both the engine compartment and driver side door).
I am left to think that the problem is related to the wiring to the ignition or ?
Only other thing not working (which I just noticed) is a rear brake light, in case that can be related in any way to the electrics to the ignition.
So, anything else that I could check before taking the car to a shop?
EDIT: When I started thinking harder, I ran out of battery earlier the day due to having the doors open for too long since I was loading my car for a trip. I got a start using cables from another vehicle. Drive approx. 80miles stop the car, start again successfully drive some 100miles more and then it won´t start.
Not the best place in the world to have a fully loaded car, with your family that won´t start, at Jökulsárlón.
(http://www.hornafjordur.is/jokulsarlon/myndasafn//album/143/)
Since I´m on the subject and you are car enthusiasts, lots of events been recorded at Jökulsárlón. New Mercedes ad, James Bond intro in View to a kill and TopGear had a race there in season 8.
http://www.hornafjordur.is/jokulsarlon/myndasafn//album/144/
Thanks in advance,
Caaine
Thanks in advance,
Caaine
