Solved: Coolant leak 95 4.0L OHV, got an odd coolant leak | Page 2 | Ford Explorer Forums
Engine block heaters are similar to the part I used.
I was never able to drive a plug in with the tool. I tried with a steel plug, it was just a bit too offset, it would pop out. Gave up.
I have a special copper plug with a tension screw. Holds for years.
It is probably welded in by now from the corrosion.
Forgot the size but its the same.
I like that plug but it says it for jeeps? Did you uses the jeep plug or something similar?
It fits any round metal hole :). You just need the diameter (I believe ours is 2").
