Did you recently have any work done on the truck? What you describe sounds like the typical power steering chatter caused by air in the system as a result of the steering being turned while the engine is off.
Start the truck, slowly moving forward or reverse turn the steering lock to lock (L to R) three or four times. That should purge the air and remove the chatter.
