91expy
- January 16, 2006
- Michigan
- '91 Eddie Bauer
Hey just got a couple of questions the output shaft gasket on the steering gear blew, so i yanked the whole gear box out. I had no problem taking out the pitman arm and the unit. When I try to reassemble im caught in a pickle.... when i pulled the unit the steering shaft came off in 2 pieces, the upper connected to wheel and the u joint and below is still on the car. The bottom portion where the rubber disk and above is off the car. Is there a trick to connect them back? Is it possible to bolt the box to the frame then connect the lower shaft? Any tips would be great its a 91 eb 4x4 thanks alot
