paul kellam
- April 28, 2012
The cd is shot in my 2003 sport trac it is a 6 table pioneer deck will the cd/stereo from a 06 ford f-150 fit and work in my track?
The stock 04+(except 04 Heritages) F150 head units will not fit in the dash of a 1st gen Sport Trac.
Stock 04 F150s have a double DIN stereo... they will fit in an ST...
F150 size is given here:
http://www.f150forum.com/f4/oem-radio-dimensions-28495/
The ST stock head unit is also a double din. it should slide right in. Im not sure if 2004 F150s had a sub or not, but the 2 / 3 wire issue sounds like that'd be the problem. If you get a wire harness like this:
http://www.stylintrucks.com/parts/b...a&ST_SRC=PPC&gclid=CInZqvHo2a8CFZDrKgod4DFXAg
you should be able to run the wires into that and make it work. But seriously... more work than its worth and the sound will still be flat. An aftermarket unit would be easier and yield better sound![]()
I don't mean to irritate you, but yes if you look at a side view, the f150 faceplate is MUCH taller than the ones that came in the 1st Gen Tracs. The 2nd gen Tracs have this radio, so if you want to go measure and compare, it just won't fit without modding the crud out of the bezel.
Oh no im not irritated! Its like the feeling when you see a movie on TV and can't remember the actors name or something like that. lol. Kinda a confused feeling when you are certain you shouldn't be!
If I had a unit to measure I would, I'll do a google search when Im not on my phone. I guess I cant figure out why there's a stereo size system if 2 head units of the same size class aren't in fact the same size! lol.
